Mumble на Windows XP и процессоре Intel Pentium 3
Добавлено: 22 мар 2016, 10:33
rezedent12
Есть несколько компьютеров с Windows XP SP3 Home, с последними обновлениями. На 2 из них процессоры Intel Pentium 3. На них mumble падает после запуска. Содержимое console.txt ничем оригинальным не отличается
<W>2016-03-22 10:14:27.031 WASAPIInit: Requires Vista SP1
<W>2016-03-22 10:14:27.031 ASIO: No valid devices found, disabling
<W>2016-03-22 10:14:27.062 G15LCDEngine_lglcd: Logitech LCD Manager not detected.
<W>2016-03-22 10:14:27.078 CELT bitstream 8000000b from C:/Program Files/Mumble/celt0.0.7.0.dll
<W>2016-03-22 10:14:27.078 CELT bitstream 80000010 from C:/Program Files/Mumble/celt0.0.11.0.dll
<W>2016-03-22 10:14:27.078 Locale is "ru_RU" (System: "ru_RU")
<W>2016-03-22 10:22:01.968 Database SQLite: "3.7.7.1"
<W>2016-03-22 10:22:01.968 Bonjour: Failed to load dnssd.dll
<W>2016-03-22 10:22:01.984 Overlay: Listening on "\\.\pipe\MumbleOverlayPipe"
<W>2016-03-22 10:22:03.343 GlobalShortcutWin: No LowLevelHooksTimeout registry key found.
<W>2016-03-22 10:22:04.578 XboxInput: no valid XInput DLL was found on the system.
<W>2016-03-22 10:22:04.578 GlobalShortcutWin: XboxInput initialized, isValid: 0
<W>2016-03-22 10:22:04.718 AudioInput: 40000 bits/s, 48000 hz, 480 sample
<W>2016-03-22 10:22:04.734 Adding device {6f1d2b60-d5a0-11cf-bfc7-444553540000} ???? ????:3
<W>2016-03-22 10:22:04.734 Adding device {6f1d2b61-d5a0-11cf-bfc7-444553540000} ?????????? ??????????:127
<W>2016-03-22 10:22:05.656 DXAudioInput: Initialized
<W>2016-03-22 10:22:05.656 DXAudioOutput: Primary buffer of 48000 Hz, 2 channels, 16 bits
<W>2016-03-22 10:22:05.656 DXAudioOutputUser: New 48000Hz output buffer of 96000 bytes
<W>2016-03-22 10:22:05.656 AudioOutput: Initialized 2 channel 48000 hz mixer
<W>2016-03-22 10:22:05.718 AudioInput: 40000 bits/s, 48000 hz, 480 sample
<W>2016-03-22 10:22:05.796 DXAudioInput: Initialized
<W>2016-03-22 10:22:05.796 DXAudioOutput: Primary buffer of 48000 Hz, 2 channels, 16 bits
<W>2016-03-22 10:22:05.796 DXAudioOutputUser: New 48000Hz output buffer of 96000 bytes
<W>2016-03-22 10:22:05.796 AudioOutput: Initialized 2 channel 48000 hz mixer
<W>2016-03-22 10:22:05.812 AudioInput: 40000 bits/s, 48000 hz, 480 sample
<W>2016-03-22 10:22:06.281 DXAudioInput: Initialized
<W>2016-03-22 10:22:06.281 DXAudioOutput: Primary buffer of 48000 Hz, 2 channels, 16 bits
<W>2016-03-22 10:22:06.281 DXAudioOutputUser: New 48000Hz output buffer of 96000 bytes
<W>2016-03-22 10:22:06.281 AudioOutput: Initialized 2 channel 48000 hz mixer
Сначала mumble выдаёт своё сообщение о ошибке, затем после его закрытия уже windows выдаёт сообщение. Так же mumble запускается долго и в ходу этой задержки в списке процессов появляется dxdiag на несколько секунд.
Чем это может быть вызвано? И как это исправить?
Re: Mumble на Windows XP и процессоре Intel Pentium 3
Добавлено: 22 мар 2016, 16:30
Специально запустил виртуалку под это дело
Чистая установка WinXP и Mumble 1.2.15 отлично работают вместе
Mumble 1.2.15 WinXP
Mumble 1.2.15 WinXP
Какая версия Mumble?
Проверьте более старые версии
Добавлено: 22 мар 2016, 17:13
rezedent12
B0nuse писал(а):Специально запустил виртуалку под это дело
Я пробовал устанавливать несколько предыдущих версий, в том числе mumble 1.2.8
Виртуальная машина не поможет воспроизвести это поведение, так как она использует аппаратную виртуализацию и поддерживает многие инструкции реального процессора. Я подозреваю дело не в операционной системе, а в сочетании процессора и операционной системы. На снимке же дисплея видно что процессор определился как Intel Core 2 Duo
Может ли быть так что сам mumble или включённые в него библиотеки скомпилированы под инструкции процессора Intel Pentium 4 и поэтому не корректно работают на предыдущих?
Добавлено: 22 мар 2016, 17:23
Я задавался данным вопросом очень давно, когда в определенный момент была убрана поддержка SSE. Тогда был разговор о том, что нужно вернуть возможность использовать эти инструкции в Mumble
На данный момент не могу однозначно ответить на Ваш вопрос. Попробуйте еще более старые версии - 1.2.4 и ниже
Добавлено: 24 мар 2016, 11:18
rezedent12
B0nuse писал(а):Я задавался данным вопросом очень давно, когда в определенный момент была убрана поддержка SSE. Тогда был разговор о том, что нужно вернуть возможность использовать эти инструкции в Mumble
Версия mumble 1.2.3a подошла. Спасибо.
Дело в ключах компиляции или в привязке самого исходного кода к SSE инструкциям?
