CentOS 6 проблемы с установкой Mumble
nookbat
Забанен
Сообщение nookbat »
Доброе время суток!
Ставил Mumble server следуя манулу http://wiki.mumble.info/wiki/Install_CentOS6
После шага :
yum install avahi-compat-libdns_sd qt qt-sqlite ice-libs protobuf
Получаю с начало:
Loaded plugins: fastestmirror
Repository zeroc-ice is listed more than once in the configuration
Loading mirror speeds from cached hostfile
Could not get metalink https://mirrors.fedoraproject.org/metalink?repo=epel-6&ar                                                   ch=i386 error was
14: problem making ssl connection
 * base: mirror.corbina.net
 * epel: mirror.logol.ru
 * extras: mirror.corbina.net
 * ius: mirrors.ircam.fr
 * nux-dextop: mirror.li.nux.ro
 * updates: mirror.corbina.net
Setting up Install Process
Resolving Dependencies
--> Running transaction check
---> Package avahi-compat-libdns_sd.i686 0:0.6.25-15.el6 will be installed
---> Package ice-libs.i386 0:3.5.1-1.el6 will be installed
--> Processing Dependency: ice = 3.5.1-1.el6 for package: ice-libs-3.5.1-1.el6.i                                                   386
--> Processing Dependency: db53 for package: ice-libs-3.5.1-1.el6.i386
--> Processing Dependency: libdb_cxx-5.3.so for package: ice-libs-3.5.1-1.el6.i3                                                   86
---> Package protobuf.i686 0:2.3.0-7.el6 will be installed
---> Package qt.i686 1:4.6.2-28.el6_5 will be installed
---> Package qt-sqlite.i686 1:4.6.2-28.el6_5 will be installed
---> Package db53.i386 0:5.3.21-1ice.el6 will be installed
---> Package ice.noarch 0:3.5.1-1.el6 will be installed
--> Finished Dependency Resolution
Dependencies Resolved
 Package                    Arch       Version              Repository     Size
Installing:
 avahi-compat-libdns_sd     i686       0.6.25-15.el6        base           28 k
 ice-libs                   i386       3.5.1-1.el6          zeroc-ice     3.5 M
 protobuf                   i686       2.3.0-7.el6          epel          289 k
 qt                         i686       1:4.6.2-28.el6_5     base          4.0 M
 qt-sqlite                  i686       1:4.6.2-28.el6_5     base           51 k
Installing for dependencies:
 db53                       i386       5.3.21-1ice.el6      zeroc-ice     1.6 M
 ice                        noarch     3.5.1-1.el6          zeroc-ice      98 k
Transaction Summary
Install       7 Package(s)
Total size: 9.6 M
Total download size: 289 k
Installed size: 31 M
Is this ok [y/N]: y
Downloading Packages:
http://mirror.logol.ru/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14] PYC                                                   URL ERROR 22 - "The requested URL returned error: 404 Not Found"
Trying other mirror.
http://mirror.datacenter.by/pub/fedoraproject.org/epel/6/i386/protobuf-2.3.0-7.e                                                   l6.i686.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404                                                    Not Found"
https://ftp.fau.de/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14] problem                                                    making ssl connection
http://ftp.nluug.nl/pub/os/Linux/distr/fedora-epel/6/i386/protobuf-2.3.0-7.el6.i                                                   686.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not                                                    Found"
http://mirror.de.leaseweb.net/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno                                                    14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.crc.dk/fedora-epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14] P                                                   YCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.nl.leaseweb.net/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno                                                    14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirrors.coreix.net/fedora-epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Err                                                   no 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://www.mirrorservice.org/sites/dl.fedoraproject.org/pub/epel/6/i386/protobuf                                                   -2.3.0-7.el6.i686.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned                                                    error: 404 Not Found"
http://mirror.omnilance.com/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14                                                   ] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.bacloud.com/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14]                                                    PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mir01.syntis.net/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14] PY                                                   CURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirrors.ircam.fr/pub/fedora/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [E                                                   rrno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://fr2.rpmfind.net/linux/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 1                                                   4] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirrors.neterra.net/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14]                                                    PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://fedora.ip-connect.vn.ua/fedora-epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm:                                                    [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.heanet.ie/pub/fedora/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errn                                                   o 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.colocall.net/pub/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14                                                   ] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.uni-bayreuth.de/linux/fedora-epel/6/i386/protobuf-2.3.0-7.el6.i686.rp                                                   m: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found                                                   "
http://fedora.tu-chemnitz.de/pub/linux/fedora-epel/6/i386/protobuf-2.3.0-7.el6.i                                                   686.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not                                                    Found"
http://mirror.fraunhofer.de/dl.fedoraproject.org/epel/6/i386/protobuf-2.3.0-7.el                                                   6.i686.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404                                                    Not Found"
http://mirror.duomenucentras.lt/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errn                                                   o 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.cc.uoc.gr/pub/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14] P                                                   YCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.awanti.com/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14] P                                                   YCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.23media.de/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14] P                                                   YCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.uni-koeln.de/mirrors/fedora/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm                                                   : [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.imt-systems.com/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno                                                    14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.digitalnova.at/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 1                                                   4] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirrors.nic.cz/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14] PYCU                                                   RL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.serverbeheren.nl/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno                                                    14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.acc.umu.se/mirror/fedora/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [                                                   Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://vesta.informatik.rwth-aachen.de/ftp/pub/Linux/fedora-epel/6/i386/protobuf                                                   -2.3.0-7.el6.i686.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned                                                    error: 404 Not Found"
http://ftp-stud.hs-esslingen.de/pub/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [                                                   Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.proserve.nl/fedora-epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Err                                                   no 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.slu.cz/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14] PYCUR                                                   L ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.uni-kl.de/pub/linux/fedora-epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm:                                                    [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://epel.check-update.co.uk/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14]                                                    PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://epel.besthosting.ua/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14] PYCU                                                   RL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.vorboss.net/fedora/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Err                                                   no 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.ibcp.fr/pub/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14]                                                    PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://fedora.aau.at/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14] PYCUR                                                   L ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.vutbr.cz/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14] PYC                                                   URL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.bytemark.co.uk/fedora/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [                                                   Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
https://anorien.csc.warwick.ac.uk/mirrors/epel/6/i386/protobuf-2.3.0-7.el6.i686.                                                   rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Fou                                                   nd"
http://mirrors.ukfast.co.uk/sites/dl.fedoraproject.org/pub/epel/6/i386/protobuf-                                                   2.3.0-7.el6.i686.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned e                                                   rror: 404 Not Found"
http://mirror.karneval.cz/pub/linux/fedora/epel/6/i386/protobuf-2.3.0-7.el6.i686                                                   .rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Fo                                                   und"
http://epel.mirrors.ovh.net/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14                                                   ] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirrors.uni-ruse.bg/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14]                                                    PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.lysator.liu.se/pub/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno                                                    14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.astral.ro/mirrors/fedora/pub/epel/6/i386/protobuf-2.3.0-7.el6.i686.rp                                                   m: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found                                                   "
http://fedora-epel.skarta.net/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14] P                                                   YCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.i3d.net/pub/fedora-epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Err                                                   no 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.fi.muni.cz/pub/linux/fedora/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm                                                   : [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.ps.pl/pub/Linux/fedora-epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Er                                                   rno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://www.fedora.is/fedora/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14                                                   ] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.nonstop.co.il/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14                                                   ] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirrors.n-ix.net/fedora-epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno                                                    14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://fedora.mirrors.telekom.ro/pub/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm:                                                    [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.linux.org.tr/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14] PY                                                   CURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.linux.cz/pub/linux/fedora/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm:                                                    [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.uninett.no/linux/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14                                                   ] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.pmf.kg.ac.rs/fedora/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Er                                                   rno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.nsc.liu.se/fedora-epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errn                                                   o 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.uv.es/mirror/fedora-epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Er                                                   rno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://fedora.uib.no/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14] PYCUR                                                   L ERROR 22 - "The requested URL returned error: 404 Not Found"
http://ftp.icm.edu.pl/pub/Linux/fedora/linux/epel/6/i386/protobuf-2.3.0-7.el6.i6                                                   86.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not                                                    Found"
http://ftp.pbone.net/pub/fedora/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errn                                                   o 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://mirror.switch.ch/ftp/mirror/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [E                                                   rrno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://repo.boun.edu.tr/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14] PY                                                   CURL ERROR 22 - "The requested URL returned error: 404 Not Found"
http://be.mirror.eurid.eu/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 14]                                                    PYCURL ERROR 6 - "Couldn't resolve host 'be.mirror.eurid.eu'"
http://mirror.oss.maxcdn.com/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 1                                                   2] Timeout on http://mirror.oss.maxcdn.com/epel/6/i386/protobuf-2.3.0-7.el6.i686                                                   .rpm: (28, 'connect() timed out!')
http://nl.mirror.eurid.eu/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno 12]                                                    Timeout on http://nl.mirror.eurid.eu/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm:                                                    (28, 'connect() timed out!')
ftp://ftp.mirrorservice.org/sites/dl.fedoraproject.org/pub/epel/6/i386/protobuf-                                                   2.3.0-7.el6.i686.rpm: [Errno 14] PYCURL ERROR 19 - "Given file does not exist"
ftp://ftp.fedora.is/pub/fedora/epel/6/i386/protobuf-2.3.0-7.el6.i686.rpm: [Errno                                                    14] PYCURL ERROR 19 - "Given file does not exist"
И в конце разумеется:
Error Downloading Packages:
  protobuf-2.3.0-7.el6.i686: failure: protobuf-2.3.0-7.el6.i686.rpm from epel:
[Errno 256] No more mirrors to try.
:help:
P.S.: а protobuf вообще на CentOS существует? :wall:
nookbat
Забанен
Re: CentOS 6 проблемы с установкой Mumble
Сообщение nookbat »
проблему решил. Решение таково - установил отдельно protobuf-2.3.0-9.el6.i686.rpm
