database=
#dbDriver=QMYSQL
#dbUsername=
#dbPassword=
#dbHost=
#dbPort=
#dbPrefix=murmur_
#dbOpts=
dbus=session
#icesecret=
#autobanAttempts = 10
#autobanTimeframe = 120
#autobanTime = 300
#logfile=murmur.log
#pidfile=
port=64738
#host=
# Password to join server
serverpassword=
# to send speech at.
bandwidth=72000
users=100
#textmessagelength=5000
#imagemessagelength=131072
#allowhtml=true
#logdays=31
# addresses.
#registerName=Mumble Server
#registerPassword=secret
#registerHostname=
# about bonjour.
#bonjour=True
#sslCert=
#sslKey=
#uname=
# to connect.
#certrequired=False
[Ice]
Ice.Warn.UnknownProperties=1
Ice.MessageSizeMax=65536
