Текст ерора:
making all in cpp
make[1]: Entering directory `/home/Ice-3.3.1/cpp'
making all in config
make[2]: Entering directory `/home/Ice-3.3.1/cpp/config'
echo ""
make[2]: Leaving directory `/home/Ice-3.3.1/cpp/config'
making all in src
make[2]: Entering directory `/home/Ice-3.3.1/cpp/src'
making all in IceUtil
make[3]: Entering directory `/home/Ice-3.3.1/cpp/src/IceUtil'
make[3]: Цель `all' не требует выполнения команд.
make[3]: Leaving directory `/home/Ice-3.3.1/cpp/src/IceUtil'
making all in Slice
make[3]: Entering directory `/home/Ice-3.3.1/cpp/src/Slice'
make[3]: Leaving directory `/home/Ice-3.3.1/cpp/src/Slice'
making all in slice2cpp
make[3]: Entering directory `/home/Ice-3.3.1/cpp/src/slice2cpp'
make[3]: Leaving directory `/home/Ice-3.3.1/cpp/src/slice2cpp'
making all in slice2cs
make[3]: Entering directory `/home/Ice-3.3.1/cpp/src/slice2cs'
make[3]: Leaving directory `/home/Ice-3.3.1/cpp/src/slice2cs'
making all in slice2freeze
make[3]: Entering directory `/home/Ice-3.3.1/cpp/src/slice2freeze'
make[3]: Leaving directory `/home/Ice-3.3.1/cpp/src/slice2freeze'
making all in slice2freezej
make[3]: Entering directory `/home/Ice-3.3.1/cpp/src/slice2freezej'
make[3]: Leaving directory `/home/Ice-3.3.1/cpp/src/slice2freezej'
making all in slice2docbook
make[3]: Entering directory `/home/Ice-3.3.1/cpp/src/slice2docbook'
make[3]: Leaving directory `/home/Ice-3.3.1/cpp/src/slice2docbook'
making all in slice2java
make[3]: Entering directory `/home/Ice-3.3.1/cpp/src/slice2java'
make[3]: Leaving directory `/home/Ice-3.3.1/cpp/src/slice2java'
making all in slice2py
make[3]: Entering directory `/home/Ice-3.3.1/cpp/src/slice2py'
make[3]: Leaving directory `/home/Ice-3.3.1/cpp/src/slice2py'
making all in slice2rb
make[3]: Entering directory `/home/Ice-3.3.1/cpp/src/slice2rb'
make[3]: Leaving directory `/home/Ice-3.3.1/cpp/src/slice2rb'
making all in slice2html
make[3]: Entering directory `/home/Ice-3.3.1/cpp/src/slice2html'
make[3]: Leaving directory `/home/Ice-3.3.1/cpp/src/slice2html'
making all in Ice
make[3]: Entering directory `/home/Ice-3.3.1/cpp/src/Ice'
make[3]: Leaving directory `/home/Ice-3.3.1/cpp/src/Ice'
making all in IceXML
make[3]: Entering directory `/home/Ice-3.3.1/cpp/src/IceXML'
c++ -c -I../../include -DICE_XML_API_EXPORTS -m64 -ftemplate-depth-128 -Wall -D _REENTRANT -I/usr/include/nptl -fPIC -g Parser.cpp
Parser.cpp:11:19: error: expat.h: Нет такого файла или каталога
Parser.cpp:311: ошибка: ‘XML_Parser’ does not name a type
Parser.cpp:319: ошибка: expected ‘,’ or ‘...’ before ‘*’ token
Parser.cpp:319: ошибка: ISO C++ запрещает декларации ‘XML_Char’ без типа
Parser.cpp: In function ‘void startElementHandler(void*, int)’:
Parser.cpp:324: ошибка: нет декларации ‘attr’ в этой области видимости
Parser.cpp:329: ошибка: ‘struct CallbackData’ has no member named ‘parser’
Parser.cpp:329: ошибка: нет декларации ‘XML_GetCurrentLineNumber’ в этой области видимости
Parser.cpp:330: ошибка: ‘struct CallbackData’ has no member named ‘parser’
Parser.cpp:330: ошибка: нет декларации ‘XML_GetCurrentColumnNumber’ в этой облас ти видимости
Parser.cpp:331: ошибка: нет декларации ‘name’ в этой области видимости
Parser.cpp: At global scope:
Parser.cpp:335: ошибка: expected ‘,’ or ‘...’ before ‘*’ token
Parser.cpp:335: ошибка: ISO C++ запрещает декларации ‘XML_Char’ без типа
Parser.cpp: In function ‘void endElementHandler(void*, int)’:
Parser.cpp:338: ошибка: ‘struct CallbackData’ has no member named ‘parser’
Parser.cpp:338: ошибка: нет декларации ‘XML_GetCurrentLineNumber’ в этой области видимости
Parser.cpp:339: ошибка: ‘struct CallbackData’ has no member named ‘parser’
Parser.cpp:339: ошибка: нет декларации ‘XML_GetCurrentColumnNumber’ в этой облас ти видимости
Parser.cpp:340: ошибка: нет декларации ‘name’ в этой области видимости
Parser.cpp:344: ошибка: expected ‘,’ or ‘...’ before ‘*’ token
Parser.cpp:344: ошибка: ISO C++ запрещает декларации ‘XML_Char’ без типа
Parser.cpp: In function ‘void characterDataHandler(void*, int)’:
Parser.cpp:348: ошибка: нет декларации ‘s’ в этой области видимости
Parser.cpp:348: ошибка: нет декларации ‘len’ в этой области видимости
Parser.cpp:349: ошибка: ‘struct CallbackData’ has no member named ‘parser’
Parser.cpp:349: ошибка: нет декларации ‘XML_GetCurrentLineNumber’ в этой области видимости
Parser.cpp:350: ошибка: ‘struct CallbackData’ has no member named ‘parser’
Parser.cpp:350: ошибка: нет декларации ‘XML_GetCurrentColumnNumber’ в этой облас ти видимости
Parser.cpp: In static member function ‘static void IceXML::Parser::parse(std::is tream&, IceXML::Handler&)’:
Parser.cpp:391: ошибка: нет декларации ‘XML_Parser’ в этой области видимости
Parser.cpp:391: ошибка: expected `;' before ‘parser’
Parser.cpp:393: ошибка: ‘struct CallbackData’ has no member named ‘parser’
Parser.cpp:393: ошибка: нет декларации ‘parser’ в этой области видимости
Parser.cpp:395: ошибка: нет декларации ‘XML_SetUserData’ в этой области видимост и
Parser.cpp:396: ошибка: нет декларации ‘XML_SetElementHandler’ в этой области ви димости
Parser.cpp:397: ошибка: нет декларации ‘XML_SetCharacterDataHandler’ в этой обла сти видимости
Parser.cpp:410: ошибка: нет декларации ‘XML_Parse’ в этой области видимости
Parser.cpp:412: ошибка: нет декларации ‘XML_GetErrorCode’ в этой области видимос ти
Parser.cpp:412: ошибка: нет декларации ‘XML_ErrorString’ в этой области видимост и
Parser.cpp:412: ошибка: нет декларации ‘XML_GetCurrentLineNumber’ в этой области видимости
Parser.cpp:413: ошибка: нет декларации ‘XML_GetCurrentColumnNumber’ в этой облас ти видимости
Parser.cpp:420: ошибка: нет декларации ‘XML_ParserFree’ в этой области видимости
Parser.cpp:424: ошибка: нет декларации ‘XML_ParserFree’ в этой области видимости
make[3]: *** [Parser.o] Ошибка 1
make[3]: Leaving directory `/home/Ice-3.3.1/cpp/src/IceXML'
make[2]: *** [all] Ошибка 1
make[2]: Leaving directory `/home/Ice-3.3.1/cpp/src'
make[1]: *** [all] Ошибка 1
make[1]: Leaving directory `/home/Ice-3.3.1/cpp'
make: *** [all] Ошибка 1
