Strict Standards: date() [function.date]: It is not safe to rely on the system's timezone settings. Please use the date.timezone setting, the TZ environment variable or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Helsinki' for '2.0/no DST' instead in D:\AppServ\www\inc\functions.php on line 24
Strict Standards: date() [function.date]: It is not safe to rely on the system's timezone settings. Please use the date.timezone setting, the TZ environment variable or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Helsinki' for '2.0/no DST' instead in D:\AppServ\www\inc\functions.php on line 25
Strict Standards: date() [function.date]: It is not safe to rely on the system's timezone settings. Please use the date.timezone setting, the TZ environment variable or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Helsinki' for '2.0/no DST' instead in D:\AppServ\www\inc\functions.php on line 26
Strict Standards: date() [function.date]: It is not safe to rely on the system's timezone settings. Please use the date.timezone setting, the TZ environment variable or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Helsinki' for '2.0/no DST' instead in D:\AppServ\www\inc\functions.php on line 27
Strict Standards: date() [function.date]: It is not safe to rely on the system's timezone settings. Please use the date.timezone setting, the TZ environment variable or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Helsinki' for '2.0/no DST' instead in D:\AppServ\www\inc\functions.php on line 28
Strict Standards: date() [function.date]: It is not safe to rely on the system's timezone settings. Please use the date.timezone setting, the TZ environment variable or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Helsinki' for '2.0/no DST' instead in D:\AppServ\www\inc\functions.php on line 29
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at D:\AppServ\www\inc\functions.php:24) in D:\AppServ\www\inc\functions.php on line 91
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at D:\AppServ\www\inc\functions.php:24) in D:\AppServ\www\inc\functions.php on line 91
Warning: Cannot modify header information - headers already sent by (output started at D:\AppServ\www\inc\functions.php:24) in D:\AppServ\www\inc\functions.php on line 106
Warning: Cannot modify header information - headers already sent by (output started at D:\AppServ\www\inc\functions.php:24) in D:\AppServ\www\inc\functions.php on line 107
Кто знает решение?
