Ошибки при установке MAP
3a4yI7aTiY
Сообщение 3a4yI7aTiY »
вот такое мне пишет
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 322
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 335
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 342
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 349
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 356
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 363
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 370
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 377
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 383
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 390
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 396
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 403
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 410
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 417
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 424
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 430
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 437
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 444
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 451
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 457
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 464
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 471
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 478
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 485
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 492
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 499
The system has been installed sucessfully!
Important:
Delete at once ../install/ - so the directory is protected by misuse.
And go now to mumb1e.de too get more informations!
If the stated path is deleted you can start with the given data!
Login with following data:
Username: SuperAdmin
Password: SuperAdmin
Go now to the Loginarea:
and announces you there with the data given on top! *CLICK*
Axe13Rus
Re: Установка MAP (веб админка для Murmur)
Сообщение Axe13Rus »
Когда захожу по этой ssылке http://localhost/install у меня пишет ошибки...
3a4yI7aTiY
допиши index.php
выскакивают выложенные ошибки....дальше никак((
стоят самые свежие релизные версии софта и мамбла последняя
В указанном файле index.php на указанной линии 322 найдите:
$install_sucess = mysql_fetch_array($qry);
замените на
$install_sucess = mysql_fetch_array($qry) or die(mysql_error());
и выложите ответ mysql_error();
Тоже самое можете проделать на всех указанных линиях.
Напоминаем:
Вышеописанная версия MAP подходит ТОЛЬКО для murmur версии 1.1.8. Для более новых версий - необходимо изменить названия некоторых таблиц в файлах.
Axe13Rus
Все равно вот что пишет...
Warning: include(../inc/_lang/english.php) [function.include]: failed to open stream: No such file or directory in D:\XAMPP\xampp\htdocs\install\index.php on line 29
Warning: include() [function.include]: Failed opening '../inc/_lang/english.php' for inclusion (include_path='.;D:\XAMPP\xampp\php\pear\') in D:\XAMPP\xampp\htdocs\install\index.php on line 29
Warning: scandir(../inc/_lang/) [function.scandir]: failed to open dir: Invalid argument in D:\XAMPP\xampp\htdocs\install\index.php on line 977
Warning: scandir() [function.scandir]: (errno 22): Invalid argument in D:\XAMPP\xampp\htdocs\install\index.php on line 977
Warning: scandir(../inc/tpl/) [function.scandir]: failed to open dir: Invalid argument in D:\XAMPP\xampp\htdocs\install\index.php on line 999
Warning: scandir() [function.scandir]: (errno 22): Invalid argument in D:\XAMPP\xampp\htdocs\install\index.php on line 999
Warning: scandir(../inc/tpl/) [function.scandir]: failed to open dir: Invalid argument in D:\XAMPP\xampp\htdocs\install\index.php on line 1007
Warning: scandir() [function.scandir]: (errno 22): Invalid argument in D:\XAMPP\xampp\htdocs\install\index.php on line 1007
/index
Axe13Rus писал(а):Все равно вот что пишет...
У Вас существует проблема с инклудом (функция include()). Разберитесь с настройкой своего сервера Apache и PHP.
3a4yI7aTiY
B0nuse писал(а):В указанном файле index.php на указанной линии 322 найдите:
замените на
Напоминаем:
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Software Foundation\Apache2.2\htdocs\install\index.php on line 322
Table 'mumble_server.murmur_map_settings' doesn't exist
3a4yI7aTiY писал(а):Table 'mumble_server.murmur_map_settings' doesn't exist
Нужны комментарии???
3a4yI7aTiY
непомешали бы))) я так понял что таблицы какойто нехватает..но я в этом не силен...кстати у немцем уже релиз MAP 2.2.1 и он работает с Mumble 1.2.2 ...тока они скачать не дают)))
3a4yI7aTiY писал(а):непомешали бы))) я так понял что таблицы какойто нехватает..но я в этом не силен...
Мы не осуществляем поддержку пользователей по вопросам работы с MySQL.
3a4yI7aTiY писал(а):кстати у немцем уже релиз MAP 2.2.1 и он работает с Mumble 1.2.2 ...тока они скачать не дают)))
Дают. За 15 евро.
