Вот что нашёл (взято
отсюда):
Installation of murmur Server on CentOS 5.4
Here's the process for installing on CentOS 5.4, using the init script and config from a mandriva rpm and the 1.2.2 static binary release:
cd ~/downloads
wget http://sourceforge.net/projects/mumble/files%2FMumble%2F1.2.2%2Fmurmur-static_x86-1.2.2.tar.lzma/download
wget ftp.isu.edu.tw/pub/Linux/Mandriva/devel/cooker/x86_64/media/contrib/release/mumble-server-1.2.2-1mdv2010.1.x86_64.rpm
cd ~/install
lzcat ../downloads/murmur-static_x86-1.2.2.tar.lzma | tar -xf -
cp murmur-static_x86-1.2.2/murmur.x86 /usr/sbin/murmurd
rpm2cpio ../downloads/mumble-server-1.2.2-1mdv2010.1.x86_64.rpm > file.lzma
lzma -d file.lzma
mkdir mumble-rpm
cd mumble-rpm
cpio -imv --make-directories < ../file
rm ../file
cp etc/mumble-server.ini /etc
cp etc/rc.d/init.d/mumble-server /etc/rc.d/init.d
chmod a+x /etc/rc.d/init.d/mumble-server
groupadd -g 4000 mumble-server
useradd -g 4000 -G mumble-server -s /sbin/nologin -d / -M mumble-server
mkdir /var/lib/mumble-server
chown mumble-server:mumble-server /var/lib/mumble-server
mkdir /var/log/mumble-server
chown mumble-server:mumble-server /var/log/mumble-server
vim /etc/rc.d/init.d/mumble-server
Change all occurrences of 'gprintf' to 'printf'
service mumble-server start
chkconfig --add mumble-server
chkconfig --level 3 mumble-server on
(thanks to dominicc on the mumble forum)
Всё идёт нормально до команды
Выдаёт: no such file or directory
Помогите пожалуста
