wl_hook.dll mumble и outpost firewall
Добавлено: 23 мар 2011, 19:15
https://wiki.mumble.info/wiki/FAQ/English от сюда
Нормального решения видимо нет до сих пор ? кроме как "uninstalling it"
1,2,2 теряет пакеты на версии сервера 1,2,3
The Mumble client does not start, or crashes when connecting (Windows)
If you are using Outpost Firewall, try uninstalling it. There is a known bug in their network component (wl_hook.dll) that will make the client crash. After removing the firewall, you need to restart your system.
