Ошибки при установке MAP
Добавлено: 31 мар 2010, 14:46
				вот такое мне пишет
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 322
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 335
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 342
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 349
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 356
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 363
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 370
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 377
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 383
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 390
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 396
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 403
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 410
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 417
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 424
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 430
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 437
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 444
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 451
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 457
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 464
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 471
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 478
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 485
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 492
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in C:\Program Files\Apache Group\Apache2\htdocs\install\index.php on line 499
The system has been installed sucessfully!
Important:
Delete at once ../install/ - so the directory is protected by misuse.
And go now to mumb1e.de too get more informations!
If the stated path is deleted you can start with the given data!
Login with following data:
Username: SuperAdmin
Password: SuperAdmin
Go now to the Loginarea:
and announces you there with the data given on top! *CLICK*
