Re: Свой Public Server
Добавлено: 07 фев 2012, 17:16
Пожалуйста, весь murmur.ini
аренда mumble, скачать mumble, настройка mumble
https://mumble.ru/forum/
[/spoiler]# Path to database. If blank, will search for
database=
#dbDriver=QMYSQL
#dbUsername=
#dbPassword=
#dbHost=
#dbPort=
#dbPrefix=murmur_
#dbOpts=
dbus=session
#icesecret=
#autobanAttempts = 10
#autobanTimeframe = 120
#autobanTime = 300
#logfile=murmur.log
#pidfile=
#welcometext="<br />Welcome to this server running <b>Murmur</b>.<br />Enjoy your stay!<br />"
welcometext="<br />Welcome to <b>UAGs team</b> mumble server<br /><img src="http://uags.info/logo.gif"/><br />"
port=8888
host=87.118.89.113
# Password to join server
#serverpassword=11111
# to send speech at.
bandwidth=100000
users=100
#textmessagelength=5000
#imagemessagelength=131072
#allowhtml=true
#logdays=31
# addresses.
registerName=Mumble
registerPassword=pas
registerUrl=http://forum.uags.info/
registerHostname=forum.uags.info
# See http://developer.apple.com/networking/b ... index.html for more information
# about bonjour.
#bonjour=True
#sslCert=
#sslKey=
#uname=
# to connect.
#certrequired=False
[Ice]
Ice.Warn.UnknownProperties=1
Ice.MessageSizeMax=65536
openssl s_client -connect mumble.hive.no:443 -CAfile /etc/ssl/certs/ca-certificates.crtКод: Выделить всё
CONNECTED(00000003)
depth=3 /C=SE/O=AddTrust AB/OU=AddTrust External TTP Network/CN=AddTrust External CA Root
verify return:1
depth=2 /C=US/ST=UT/L=Salt Lake City/O=The USERTRUST Network/OU=http://www.usertrust.com/CN=UTN-USERFirst-Hardware
verify return:1
depth=1 /C=NL/O=TERENA/CN=TERENA SSL CA
verify return:1
depth=0 /C=NO/O=H\xC3\xB8gskolen i Vestfold/OU=IT-Fellestjenester/CN=mumble.hive.no
verify return:1
Certificate chain
0 s:/C=NO/O=H\xC3\xB8gskolen i Vestfold/OU=IT-Fellestjenester/CN=mumble.hive.no
i:/C=NL/O=TERENA/CN=TERENA SSL CA
1 s:/C=SE/O=AddTrust AB/OU=AddTrust External TTP Network/CN=AddTrust External CA Root
i:/C=SE/O=AddTrust AB/OU=AddTrust External TTP Network/CN=AddTrust External CA Root
2 s:/C=US/ST=UT/L=Salt Lake City/O=The USERTRUST Network/OU=http://www.usertrust.com/CN=UTN-USERFirst-Hardware
3 s:/C=NL/O=TERENA/CN=TERENA SSL CA
i:/C=US/ST=UT/L=Salt Lake City/O=The USERTRUST Network/OU=http://www.usertrust.com/CN=UTN-USERFirst-Hardware
Server certificate
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
subject=/C=NO/O=H\xC3\xB8gskolen i Vestfold/OU=IT-Fellestjenester/CN=mumble.hive.no
issuer=/C=NL/O=TERENA/CN=TERENA SSL CA
No client certificate CA names sent
SSL handshake has read 5233 bytes and written 331 bytes
New, TLSv1/SSLv3, Cipher is DHE-RSA-AES256-SHA
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
SSL-Session:
Protocol : TLSv1
Cipher : DHE-RSA-AES256-SHA
Session-ID: 379FDE1E69BCE063E97100EACA7F97EED6DF23281049B3F097783F0F72959FAA
Session-ID-ctx:
Master-Key: 84603317CBDA34FAD03D6911668942E14BDD1E4FDD34FE858946A133DB18A716 F2F93516C7A774277BA816F7093314E5
Key-Arg : None
Start Time: 1328634392
Timeout : 300 (sec)
Verify return code: 0 (ok)
closed
serverpassword=
registerName=UAGs Community
registerPassword=kjfhds
registerHostname=forum.uags.infoКод: Выделить всё
Registration: New registration successfullДанная строка появляется при первой регистрации сервера.Registration: New registration successfull
Пожалуйста, весь murmur.logRegistration: Registration updated
