Страница 3 из 7
Re: Мамбл зависает при запуске
Добавлено: 21 ноя 2011, 22:18
Bankai
Проблема как у автора, Mumble 1.2.3 win7 x64
Вот что пишет в логах...
<W>2011-11-21 23:06:55.755 DirectSound: Disabled as WASAPI is available
<W>2011-11-21 23:06:55.755 ASIO: No valid devices found, disabling
<W>2011-11-21 23:06:55.755 LGLCD: Unable to initialize Logitech LCD library 1722
<W>2011-11-21 23:06:55.756 CELT bitstream 8000000b from C:/Program Files (x86)/Mumble/celt0.0.7.0.sse2.dll
<W>2011-11-21 23:06:55.760 CELT bitstream 80000010 from C:/Program Files (x86)/Mumble/celt0.0.11.0.sse2.dll
<W>2011-11-21 23:06:55.761 Locale is ru_RU
<W>2011-11-21 23:06:55.964 Database SQLite: "3.6.19"
<W>2011-11-21 23:06:55.964 Bonjour: Failed to load dnssd.dll
<W>2011-11-21 23:06:56.021 Overlay: Listening on "\\.\pipe\MumbleOverlayPipe"
<W>2011-11-21 23:06:56.294 AudioInput: 40000 bits/s, 48000 hz, 480 sample CELT
<W>2011-11-21 23:06:56.297 WASAPIOutput: Latencies 100000 30000 => 100000
<W>2011-11-21 23:06:56.297 WASAPIInput: Latencies 100000 30000 => 100000
<W>2011-11-21 23:06:56.303 Adding device {6f1d2b60-d5a0-11cf-bfc7-444553540000} ???? ????:8
<W>2011-11-21 23:06:56.304 Adding device {6f1d2b61-d5a0-11cf-bfc7-444553540000} ?????????? ??????????:127
<W>2011-11-21 23:06:56.306 Adding device {e0167ca0-f12c-11e0-8002-444553540000} HID-??????????? ?????????? ?????????? HID-??????????? ?????????? ??????????:10
<W>2011-11-21 23:06:56.317 Adding device {e016a3b0-f12c-11e0-8004-444553540000} USB Keyboard USB Keyboard:3
<W>2011-11-21 23:06:56.330 Adding device {e016cac0-f12c-11e0-8005-444553540000} USB Keyboard USB Keyboard:24
<W>2011-11-21 23:06:57.996 OpenSSL Support: 1 (OpenSSL 1.0.0c 2 Dec 2010)
<W>2011-11-21 23:06:57.996 SSL: Adding recommended CA AAA Certificate Services
<W>2011-11-21 23:06:57.997 SSL: Adding recommended CA UTN-USERFirst-Client Authentication and Email
<W>2011-11-21 23:06:57.999 ServerHandler: QOS2 loaded
<W>2011-11-21 23:06:59.055 QFSFileEngine::open: No file name specified
Кто подскажет что делать ? если попытаться закрыть mumble через "выход" он висит в трее и не реагирует, также в процессах - приходится его убивать из процессов.
Добавлено: 02 дек 2011, 10:47
Запустите диспетчер задач, убейте процесс mumble.exe и запустите его вновь. Должно помочь.
Повисает Мамбл
Добавлено: 22 дек 2011, 21:43
Wenzel
Периодически повисает мамбл, в других программах голосовой связи таких проблем нет, пробовал копался в настройках, запускал от имени администратора, менял приоритет процесса, единственное что снизилось количество провисаний.
лог:
Console.rar
(74.85 КБ) 1693 скачивания
System Information
Time of this report: 12/22/2011, 20:10:25
Machine name: EMELMAN
Operating System: Windows 7 Максимальная 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110622-1506)
Language: Russian (Regional Setting: Russian)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: H67M-D2
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz (4 CPUs), ~3.1GHz
Memory: 4096MB RAM
Available OS Memory: 4080MB RAM
Page File: 1767MB used, 8427MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: ATI Radeon HD 5700 Series
Manufacturer: Advanced Micro Devices, Inc.
Chip type: ATI display adapter (0x68B8)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_68B8&SUBSYS_E144174B&REV_00
Display Memory: 2798 MB
Dedicated Memory: 1014 MB
Shared Memory: 1783 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor Name: Универсальный монитор PnP
Monitor Model: L1750S
Monitor Id: GSM43CC
Native Mode: 1280 x 1024(p) (60.020Hz)
Output Type: HD15
Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1107 (English)
Driver Version: 8.920.0.0
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 11/10/2011 09:15:20, 927232 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71EE2-2BF8-11CF-A870-4EC1BEC2C535}
Vendor ID: 0x1002
Device ID: 0x68B8
SubSys ID: 0xE144174B
Revision ID: 0x0000
Driver Strong Name: oem28.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_Evergreen:8.920.0.0:pci\ven_1002&dev_68b8
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Динамики (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0887&SUBSYS_1458A002&REV_1003
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6449 (English)
WHQL Logo'd: Yes
Date and Size: 8/30/2011 15:28:46, 3069032 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Динамики (Avnex Virtual Audio Device)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: {0.0.0.00000000}.{a22e195e-1830-49eb-a59f-3824b8c1e3bc}
Driver Version: ()
WHQL Logo'd: n/a
Date and Size: , 0 bytes
Other Files:
Driver Provider: AVNEX Ltd.
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Микрофон (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Стерео микшер (Realtek High Definition Audio)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x1
Description: Микрофон (Avnex Virtual Audio Device)
Driver Name: {0.0.1.00000000}.{71801653-b36b-4bdb-a6cf-70325688afe0}
Driver Version: ()
Cap Flags: 0x1
Re: Повисает Мамбл
Добавлено: 23 дек 2011, 06:28
Что значит провисает?
Начинает съедать много процессорного времени?
Сколько в системе стоит частота дискретизации на Динамиках? (Панель управления -> Оборудование и звук -> Звук -> Динамики -> Свойства -> Вкладка "Дополнительно")
Re: Повисает Мамбл
Добавлено: 23 дек 2011, 09:25
Wenzel
Повисает звук и вместе с ним компьютер, приходится делать ребут.
16 бит - 48000 Hz у динамиков у микрафона 16 бит- 44100 Hz, раньше стояли более высокие но японизил их в поисках решения проблемы с Мамбл
Re: Повисает Мамбл
Добавлено: 23 дек 2011, 11:11
48KHz - это нормально.
Убедитесь, что "монопольный режим" выключен в настройках звука ОС (ввод/вывод).
А также, проверьте обновления драйверов для Вашей звуковой карты.
Re: Повисает Мамбл
Добавлено: 23 дек 2011, 12:36
Wenzel
Стоит последняя версия драйверов, монопольный режим отключил повисания не прекратились.
Re: Повисает Мамбл
Добавлено: 23 дек 2011, 12:46
Попробуйте другую версию Мамбл, в том числе из тестовых билдов.
Re: Повисает Мамбл
Добавлено: 23 дек 2011, 15:47
Wenzel
пробовал уже несколько сборок, заметил что когда ставлю большие задержки вывода и много аудио на пакет зависает гораздо чаще
Re: Повисает Мамбл
Добавлено: 23 дек 2011, 16:11
тогда попробуйте отключить позиционирование звука, оверлей и подавление эха в клиенте.
