openSUSE, murmur1.2.2. Не Могу разобраться с Ice
Re: openSUSE, murmur1.2.2. Не Могу разобраться с Ice
phpinfo() в студию
PHP Version 5.3.1
System Linux linux-75tb 2.6.31.12-0.2-default #1 SMP 2010-03-16 21:25:39 +0100 i686
Build Date Feb 15 2010 17:02:57
Configure Command '../configure' '--prefix=/usr' '--datadir=/usr/share/php5' '--mandir=/usr/share/man' '--bindir=/usr/bin' '--with-libdir=lib' '--includedir=/usr/include' '--sysconfdir=/etc/php5/apache2' '--with-config-file-path=/etc/php5/apache2' '--with-config-file-scan-dir=/etc/php5/conf.d' '--enable-libxml' '--enable-session' '--with-mm' '--with-pcre-regex=/usr' '--enable-xml' '--enable-simplexml' '--enable-spl' '--enable-filter' '--disable-debug' '--enable-inline-optimization' '--disable-rpath' '--disable-static' '--enable-shared' '--program-suffix=5' '--with-pic' '--with-gnu-ld' '--with-system-tzdata=/usr/share/zoneinfo' '--with-apxs2=/usr/sbin/apxs2' '--disable-all' '--disable-cli'
Server API Apache 2.0 Handler
Virtual Directory Support disabled
Configuration File (php.ini) Path /etc/php5/apache2
Loaded Configuration File /etc/php5/apache2/php.ini
Scan this dir for additional .ini files /etc/php5/conf.d
Additional .ini files parsed /etc/php5/conf.d/bcmath.ini, /etc/php5/conf.d/bz2.ini, /etc/php5/conf.d/calendar.ini, /etc/php5/conf.d/ctype.ini, /etc/php5/conf.d/curl.ini, /etc/php5/conf.d/dba.ini, /etc/php5/conf.d/dbase.ini, /etc/php5/conf.d/dom.ini, /etc/php5/conf.d/enchant.ini, /etc/php5/conf.d/exif.ini, /etc/php5/conf.d/fileinfo.ini, /etc/php5/conf.d/ftp.ini, /etc/php5/conf.d/gd.ini, /etc/php5/conf.d/geoip.ini, /etc/php5/conf.d/gettext.ini, /etc/php5/conf.d/gmp.ini, /etc/php5/conf.d/hash.ini, /etc/php5/conf.d/ice.ini, /etc/php5/conf.d/iconv.ini, /etc/php5/conf.d/imap.ini, /etc/php5/conf.d/intl.ini, /etc/php5/conf.d/json.ini, /etc/php5/conf.d/ldap.ini, /etc/php5/conf.d/mbstring.ini, /etc/php5/conf.d/mcrypt.ini, /etc/php5/conf.d/mysql.ini, /etc/php5/conf.d/mysqli.ini, /etc/php5/conf.d/odbc.ini, /etc/php5/conf.d/openssl.ini, /etc/php5/conf.d/pcntl.ini, /etc/php5/conf.d/pdo.ini, /etc/php5/conf.d/pdo_mysql.ini, /etc/php5/conf.d/pdo_odbc.ini, /etc/php5/conf.d/pdo_pgsql.ini, /etc/php5/conf.d/pdo_sqlite.ini, /etc/php5/conf.d/pgsql.ini, /etc/php5/conf.d/phar.ini, /etc/php5/conf.d/posix.ini, /etc/php5/conf.d/pspell.ini, /etc/php5/conf.d/readline.ini, /etc/php5/conf.d/shmop.ini, /etc/php5/conf.d/snmp.ini, /etc/php5/conf.d/soap.ini, /etc/php5/conf.d/sockets.ini, /etc/php5/conf.d/sqlite.ini, /etc/php5/conf.d/sqlite3.ini, /etc/php5/conf.d/suhosin.ini, /etc/php5/conf.d/sysvmsg.ini, /etc/php5/conf.d/sysvsem.ini, /etc/php5/conf.d/sysvshm.ini, /etc/php5/conf.d/tidy.ini, /etc/php5/conf.d/tokenizer.ini, /etc/php5/conf.d/wddx.ini, /etc/php5/conf.d/xmlreader.ini, /etc/php5/conf.d/xmlrpc.ini, /etc/php5/conf.d/xmlwriter.ini, /etc/php5/conf.d/xsl.ini, /etc/php5/conf.d/zip.ini, /etc/php5/conf.d/zlib.ini
PHP API 20090626
PHP Extension 20090626
Zend Extension 220090626
Zend Extension Build API220090626,NTS
PHP Extension Build API20090626,NTS
Debug Build no
Thread Safety disabled
Zend Memory Manager enabled
Zend Multibyte Support disabled
IPv6 Support enabled
Registered PHP Streams compress.bzip2, php, file, glob, data, http, ftp, https, ftps, compress.zlib, zip, phar
Registered Stream Socket Transports tcp, udp, unix, udg, ssl, sslv3, sslv2, tls
Registered Stream Filters bzip2.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, dechunk, convert.iconv.*, zlib.*
This program makes use of the Zend Scripting Language Engine:
Zend Engine v2.3.0, Copyright (c) 1998-2009 Zend Technologies
with Suhosin v0.9.29, Copyright (c) 2007, by SektionEins GmbH
PHP Credits
Configuration
apache2handler
Apache Version Apache
Apache API Version 20051115
Server Administrator horonitel@gmail.com
Hostname:Port sauerclan.ru:0
User/Group wwwrun(30)/8
Max Requests Per Child: 10000 - Keep Alive: on - Max Per Connection: 100
Timeouts Connection: 300 - Keep-Alive: 15
Virtual Server Yes
Server Root /srv/www
Loaded Modules core prefork http_core mod_so mod_actions mod_alias mod_auth_basic mod_authn_file mod_authz_host mod_authz_groupfile mod_authz_default mod_authz_user mod_autoindex mod_cgi mod_dir mod_env mod_expires mod_include mod_log_config mod_mime mod_negotiation mod_setenvif mod_ssl mod_userdir mod_php5
Directive Local Value Master Value
engine 1 1
last_modified 0 0
xbithack 0 0
Apache Environment
Variable Value
HTTP_HOST 192.168.5.2
HTTP_CONNECTION keep-alive
HTTP_ACCEPT application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
HTTP_USER_AGENT Mozilla/5.0 (X11; U; Linux i686; en-US) AppleWebKit/534.3 (KHTML, like Gecko) Chrome/6.0.472.63 Safari/534.3
HTTP_ACCEPT_ENCODING gzip,deflate,sdch
HTTP_ACCEPT_LANGUAGE ru-RU,ru;q=0.8,en-US;q=0.6,en;q=0.4
HTTP_ACCEPT_CHARSET windows-1251,utf-8;q=0.7,*;q=0.3
HTTP_COOKIE __utmz=18754809.1285941579.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); PHPSESSID=see31uahnks95ehe6fb5mdl8nq7h8f6e; __utma=18754809.1389112700.1285941579.1285941579.1286956130.2; __utmc=18754809; __utmb=18754809.1.10.1286956130
PATH /home/lisss/bin:/usr/local/bin:/usr/bin:/sbin:/usr/sbin:/bin:/usr/X11R6/bin:/usr/games:/usr/lib/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin
SERVER_SIGNATURE no value
SERVER_SOFTWARE Apache
SERVER_NAME 192.168.5.2
SERVER_ADDR 192.168.5.2
SERVER_PORT 80
REMOTE_ADDR 192.168.5.3
DOCUMENT_ROOT /srv/www/sauerclan
SERVER_ADMIN horonitel@gmail.com
SCRIPT_FILENAME /srv/www/sauerclan/phpi.php
REMOTE_PORT 59602
GATEWAY_INTERFACE CGI/1.1
SERVER_PROTOCOL HTTP/1.1
REQUEST_METHOD GET
QUERY_STRING no value
REQUEST_URI /phpi.php
SCRIPT_NAME /phpi.php
HTTP Headers Information
HTTP Request Headers
HTTP Request GET /phpi.php HTTP/1.1
Host 192.168.5.2
Connection keep-alive
Accept application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
User-Agent Mozilla/5.0 (X11; U; Linux i686; en-US) AppleWebKit/534.3 (KHTML, like Gecko) Chrome/6.0.472.63 Safari/534.3
Accept-Encoding gzip,deflate,sdch
Accept-Language ru-RU,ru;q=0.8,en-US;q=0.6,en;q=0.4
Accept-Charset windows-1251,utf-8;q=0.7,*;q=0.3
Cookie __utmz=18754809.1285941579.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); PHPSESSID=see31uahnks95ehe6fb5mdl8nq7h8f6e; __utma=18754809.1389112700.1285941579.1285941579.1286956130.2; __utmc=18754809; __utmb=18754809.1.10.1286956130
HTTP Response Headers
X-Powered-By PHP/5.3.1
Keep-Alive timeout=15, max=100
Connection Keep-Alive
Transfer-Encoding chunked
Content-Type text/html
bcmath
BCMath support enabled
bcmath.scale 0 0
bz2
BZip2 Support Enabled
Stream Wrapper support compress.bz2://
Stream Filter support bzip2.decompress, bzip2.compress
BZip2 Version 1.0.5, 10-Dec-2007
calendar
Calendar support enabled
Core
PHP Version 5.3.1
allow_call_time_pass_reference Off Off
allow_url_fopen On On
allow_url_include Off Off
always_populate_raw_post_data Off Off
arg_separator.input & &
arg_separator.output & &
asp_tags Off Off
auto_append_file no value no value
auto_globals_jit On On
auto_prepend_file no value no value
browscap no value no value
default_charset no value no value
default_mimetype text/html text/html
define_syslog_variables Off Off
disable_classes no value no value
disable_functions no value no value
display_errors Off Off
display_startup_errors Off Off
doc_root no value no value
docref_ext no value no value
docref_root no value no value
enable_dl Off Off
error_append_string no value no value
error_log /var/log/php/php_error.log /var/log/php/php_error.log
error_prepend_string no value no value
error_reporting 30719 30719
exit_on_timeout Off Off
expose_php On On
extension_dir /usr/lib/php5/extensions /usr/lib/php5/extensions
file_uploads On On
highlight.bg #FFFFFF #FFFFFF
highlight.comment #FF8000 #FF8000
highlight.default #0000BB #0000BB
highlight.html #000000 #000000
highlight.keyword #007700 #007700
highlight.string #DD0000 #DD0000
html_errors Off Off
ignore_repeated_errors Off Off
ignore_repeated_source Off Off
ignore_user_abort Off Off
implicit_flush Off Off
include_path .:/usr/lib/php5/extensions:/usr/share/php5:/usr/share/php5/PEAR .:/usr/lib/php5/extensions:/usr/share/php5:/usr/share/php5/PEAR
log_errors On On
log_errors_max_len 1024 1024
magic_quotes_gpc Off Off
magic_quotes_runtime Off Off
magic_quotes_sybase Off Off
mail.add_x_header Off Off
mail.force_extra_parameters no value no value
mail.log no value no value
max_execution_time 30 30
max_file_uploads 20 20
max_input_nesting_level 64 64
max_input_time 60 60
memory_limit 128M 128M
open_basedir no value no value
output_buffering 4096 4096
output_handler no value no value
post_max_size 8M 8M
precision 14 14
realpath_cache_size 16K 16K
realpath_cache_ttl 120 120
register_argc_argv Off Off
register_globals Off Off
register_long_arrays Off Off
report_memleaks On On
report_zend_debug On On
request_order no value no value
safe_mode Off Off
safe_mode_exec_dir no value no value
safe_mode_gid Off Off
safe_mode_include_dir no value no value
sendmail_from no value no value
sendmail_path /usr/sbin/sendmail -t -i /usr/sbin/sendmail -t -i
serialize_precision 100 100
short_open_tag Off Off
SMTP localhost localhost
smtp_port 25 25
sql.safe_mode Off Off
track_errors Off Off
unserialize_callback_func no value no value
upload_max_filesize 200M 200M
upload_tmp_dir /tmp/php-upload /tmp/php-upload
user_dir no value no value
user_ini.cache_ttl 300 300
user_ini.filename .user.ini .user.ini
variables_order GPCS GPCS
xmlrpc_error_number 0 0
xmlrpc_errors Off Off
y2k_compliance On On
zend.enable_gc On On
ctype
ctype functions enabled
curl
cURL support enabled
cURL Information 7.19.6
Age 3
Features
AsynchDNS No
Debug No
GSS-Negotiate Yes
IDN Yes
IPv6 Yes
Largefile Yes
NTLM Yes
SPNEGO No
SSL Yes
SSPI No
krb4 No
libz Yes
CharConv No
Protocols tftp, ftp, telnet, dict, ldap, http, file, https, ftps
Host i686-pc-linux-gnu
SSL Version OpenSSL/0.9.8k
ZLib Version 1.2.3
date
date/time support enabled
"Olson" Timezone Database Version 0.system
Timezone Database internal
Default timezone Europe/Moscow
date.default_latitude 31.7667 31.7667
date.default_longitude 35.2333 35.2333
date.sunrise_zenith 90.583333 90.583333
date.sunset_zenith 90.583333 90.583333
date.timezone no value no value
dba
DBA support enabled
Supported handlers cdb cdb_make db4 inifile flatfile
dba.default_handler flatfile flatfile
dom
DOM/XML enabled
DOM/XML API Version 20031129
libxml Version 2.7.3
HTML Support enabled
XPath Support enabled
XPointer Support enabled
Schema Support enabled
RelaxNG Support enabled
enchant
enchant support enabled
Version 1.1.0
Libenchant Version 1.5.x
Revision $Revision: 289597 $
ispell Ispell Provider /usr/lib/enchant/libenchant_ispell.so
aspell Aspell Provider /usr/lib/enchant/libenchant_aspell.so
myspell Myspell Provider /usr/lib/enchant/libenchant_myspell.so
ereg
Regex Library Bundled library enabled
exif
EXIF Support enabled
EXIF Version 1.4 $Id: exif.c 287372 2009-08-16 14:32:32Z iliaa $
Supported EXIF Version 0220
Supported filetypes JPEG,TIFF
exif.decode_jis_intel JIS JIS
exif.decode_jis_motorola JIS JIS
exif.decode_unicode_intel UCS-2LE UCS-2LE
exif.decode_unicode_motorola UCS-2BE UCS-2BE
exif.encode_jis no value no value
exif.encode_unicode ISO-8859-15 ISO-8859-15
fileinfo
fileinfo support enabled
version 1.0.5-dev
filter
Input Validation and Filtering enabled
Revision $Revision: 289434 $
filter.default unsafe_raw unsafe_raw
filter.default_flags no value no value
ftp
FTP support enabled
gd
GD Support enabled
GD Version bundled (2.0.34 compatible)
FreeType Support enabled
FreeType Linkage with freetype
FreeType Version 2.3.9
T1Lib Support enabled
GIF Read Support enabled
GIF Create Support enabled
JPEG Support enabled
libJPEG Version 6b
PNG Support enabled
libPNG Version 1.2.39
WBMP Support enabled
XPM Support enabled
XBM Support enabled
gd.jpeg_ignore_warning 0 0
geoip
geoip support enabled
geoip extension version 1.0.7
geoip library version 1004006
geoip.custom_directory no value no value
gettext
GetText Support enabled
gmp
gmp support enabled
GMP version 4.3.1
hash
hash support enabled
Hashing Engines md2 md4 md5 sha1 sha224 sha256 sha384 sha512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost adler32 crc32 crc32b salsa10 salsa20 haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
iconv
iconv support enabled
iconv implementation glibc
iconv library version 2.10.1
iconv.input_encoding ISO-8859-1 ISO-8859-1
iconv.internal_encoding ISO-8859-1 ISO-8859-1
iconv.output_encoding ISO-8859-1 ISO-8859-1
imap
IMAP c-Client Version 2004
SSL Support enabled
intl
Internationalization support enabled
version 1.0.0
ICU version 4.2
intl.default_locale no value no value
intl.error_level 0 0
json
json support enabled
json version 1.2.1
ldap
LDAP Support enabled
RCS Version $Id: ldap.c 287897 2009-08-30 15:33:59Z iliaa $
Total Links 0/unlimited
API Version 3001
Vendor Name OpenLDAP
Vendor Version 20417
SASL Support Enabled
ldap.max_links Unlimited Unlimited
libxml
libXML support active
libXML Compiled Version 2.7.3
libXML Loaded Version 20703
libXML streams enabled
mbstring
Multibyte Support enabled
Multibyte string engine libmbfl
HTTP input encoding translation disabled
mbstring extension makes use of "streamable kanji code filter and converter", which is distributed under the GNU Lesser General Public License version 2.1.
Multibyte (japanese) regex support enabled
Multibyte regex (oniguruma) backtrack check On
Multibyte regex (oniguruma) version 4.7.1
mbstring.detect_order no value no value
mbstring.encoding_translation Off Off
mbstring.func_overload 0 0
mbstring.http_input pass pass
mbstring.http_output pass pass
mbstring.http_output_conv_mimetypes ^(text/|application/xhtml\+xml) ^(text/|application/xhtml\+xml)
mbstring.internal_encoding no value no value
mbstring.language neutral neutral
mbstring.strict_detection Off Off
mbstring.substitute_character no value no value
mcrypt
mcrypt support enabled
Version 2.5.8
Api No 20021217
Supported ciphers idea mars rc6 skipjack cast-128 gost rijndael-128 twofish arcfour cast-256 loki97 rijndael-192 saferplus wake blowfish-compat des rijndael-256 serpent xtea blowfish enigma rc2 tripledes
Supported modes cbc cfb ctr ecb ncfb nofb ofb stream
mcrypt.algorithms_dir no value no value
mcrypt.modes_dir no value no value
mhash
MHASH support Enabled
MHASH API Version Emulated Support
mysql
MySQL Support enabled
Active Persistent Links 0
Active Links 0
Client API version 5.1.36
MYSQL_MODULE_TYPE external
MYSQL_SOCKET /var/run/mysql/mysql.sock
MYSQL_INCLUDE -I/usr/include/mysql
MYSQL_LIBS -L/usr/lib -lmysqlclient
mysql.allow_local_infile On On
mysql.allow_persistent Off Off
mysql.connect_timeout 60 60
mysql.default_host no value no value
mysql.default_password no value no value
mysql.default_port no value no value
mysql.default_socket /var/run/mysql/mysql.sock /var/run/mysql/mysql.sock
mysql.default_user no value no value
mysql.max_links Unlimited Unlimited
mysql.max_persistent Unlimited Unlimited
mysql.trace_mode Off Off
mysqli
MysqlI Support enabled
Client API library version 5.1.36
Inactive Persistent Links 0
Active Links 0
Client API header version 5.1.36
MYSQLI_SOCKET /var/run/mysql/mysql.sock
mysqli.allow_local_infile On On
mysqli.allow_persistent On On
mysqli.default_host no value no value
mysqli.default_port 3306 3306
mysqli.default_pw no value no value
mysqli.default_socket /var/run/mysql/mysql.sock /var/run/mysql/mysql.sock
mysqli.default_user no value no value
mysqli.max_links Unlimited Unlimited
mysqli.max_persistent Unlimited Unlimited
mysqli.reconnect Off Off
odbc
ODBC Support enabled
Active Links 0
ODBC library unixODBC
ODBC_INCLUDE -I/usr/include
ODBC_LFLAGS -L/usr/lib
ODBC_LIBS -lodbc
odbc.allow_persistent Off Off
odbc.check_persistent On On
odbc.default_cursortype Static cursor Static cursor
odbc.default_db no value no value
odbc.default_pw no value no value
odbc.default_user no value no value
odbc.defaultbinmode return as is return as is
odbc.defaultlrl return up to 4096 bytes return up to 4096 bytes
odbc.max_links Unlimited Unlimited
odbc.max_persistent Unlimited Unlimited
openssl
OpenSSL support enabled
OpenSSL Library Version OpenSSL 0.9.8k 25 Mar 2009
OpenSSL Header Version OpenSSL 0.9.8k 25 Mar 2009
pcntl
pcntl support enabled
pcre
PCRE (Perl Compatible Regular Expressions) Support enabled
PCRE Library Version 7.9 2009-04-11
pcre.backtrack_limit 100000 100000
pcre.recursion_limit 100000 100000
PDO
PDO support enabled
PDO drivers mysql, odbc, pgsql, sqlite, sqlite2
pdo_mysql
PDO Driver for MySQL enabled
PDO_ODBC
PDO Driver for ODBC (unixODBC) enabled
ODBC Connection Pooling Enabled, strict matching
pdo_pgsql
PDO Driver for PostgreSQL enabled
PostgreSQL(libpq) Version 8.4.2
Module version 1.0.2
Revision $Id: pdo_pgsql.c 277898 2009-03-28 01:58:49Z mbeccati $
pdo_sqlite
PDO Driver for SQLite 3.x enabled
SQLite Library 3.6.16
pgsql
PostgreSQL Support enabled
Multibyte character support enabled
SSL support enabled
Active Links 0
pgsql.allow_persistent Off Off
pgsql.auto_reset_persistent Off Off
pgsql.ignore_notice Off Off
pgsql.log_notice Off Off
pgsql.max_links Unlimited Unlimited
pgsql.max_persistent Unlimited Unlimited
Phar
Phar: PHP Archive support enabled
Phar EXT version 2.0.1
Phar API version 1.1.1
CVS revision $Revision: 286338 $
Phar-based phar archives enabled
Tar-based phar archives enabled
ZIP-based phar archives enabled
gzip compression enabled
bzip2 compression enabled
Phar based on pear/PHP_Archive, original concept by Davey Shafik.
Phar fully realized by Gregory Beaver and Marcus Boerger.
Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle.
phar.cache_list no value no value
phar.readonly On On
phar.require_hash On On
posix
Revision $Revision: 289424 $
pspell
PSpell Support enabled
Reflection
Reflection enabled
Version $Revision: 287991 $
session
Session Support enabled
Registered save handlers files user mm sqlite
Registered serializer handlers php php_binary wddx
session.auto_start Off Off
session.bug_compat_42 Off Off
session.bug_compat_warn On On
session.cache_expire 180 180
session.cache_limiter nocache nocache
session.cookie_domain no value no value
session.cookie_httponly On On
session.cookie_lifetime 0 0
session.cookie_path / /
session.cookie_secure Off Off
session.entropy_file /dev/urandom /dev/urandom
session.entropy_length 16 16
session.gc_divisor 1000 1000
session.gc_maxlifetime 1440 1440
session.gc_probability 1 1
session.hash_bits_per_character 5 5
session.hash_function 1 1
session.name PHPSESSID PHPSESSID
session.referer_check no value no value
session.save_handler files files
session.save_path /var/lib/php5 /var/lib/php5
session.serialize_handler php php
session.use_cookies On On
session.use_only_cookies On On
session.use_trans_sid 0 0
shmop
shmop support enabled
SimpleXML
Simplexml support enabled
Revision $Revision: 281953 $
Schema support enabled
snmp
NET-SNMP Support enabled
NET-SNMP Version 5.4.2.1
soap
Soap Client enabled
Soap Server enabled
soap.wsdl_cache 1 1
soap.wsdl_cache_dir /tmp /tmp
soap.wsdl_cache_enabled 1 1
soap.wsdl_cache_limit 5 5
soap.wsdl_cache_ttl 86400 86400
sockets
Sockets Support enabled
SPL
SPL support enabled
Interfaces Countable, OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject
Classes AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException
SQLite
SQLite support enabled
PECL Module version 2.0-dev $Id: sqlite.c 289598 2009-10-12 22:37:52Z pajoye $
SQLite Library 2.8.17
SQLite Encoding UTF-8
sqlite.assoc_case 0 0
sqlite3
SQLite3 support enabled
SQLite3 module version 0.7-dev
sqlite3.extension_dir no value no value
standard
Dynamic Library Support enabled
Path to sendmail /usr/sbin/sendmail -t -i
assert.active 1 1
assert.bail 0 0
assert.callback no value no value
assert.quiet_eval 0 0
assert.warning 1 1
auto_detect_line_endings 0 0
default_socket_timeout 60 60
safe_mode_allowed_env_vars PHP_ PHP_
safe_mode_protected_env_vars GCONV_PATH,GETCONF_DIR,HOSTALIASES,LD_AUDIT,LD_DEBUG,LD_DEBUG_OUTPUT,LD_DYNAMIC_WEAK,LD_LIBRARY_PATH,LD_ORIGIN_PATH,LD_PRELOAD,LD_PROFILE,LD_SHOW_AUXV,LD_USE_LOAD_BIAS,LOCALDOMAIN,LOCPATH,MALLOC_TRACE,NLSPATH,RESOLV_HOST_CONF,RES_OPTIONS,TMPDIR,TZDIR GCONV_PATH,GETCONF_DIR,HOSTALIASES,LD_AUDIT,LD_DEBUG,LD_DEBUG_OUTPUT,LD_DYNAMIC_WEAK,LD_LIBRARY_PATH,LD_ORIGIN_PATH,LD_PRELOAD,LD_PROFILE,LD_SHOW_AUXV,LD_USE_LOAD_BIAS,LOCALDOMAIN,LOCPATH,MALLOC_TRACE,NLSPATH,RESOLV_HOST_CONF,RES_OPTIONS,TMPDIR,TZDIR
url_rewriter.tags a=href,area=href,frame=src,input=src,form=fakeentry a=href,area=href,frame=src,input=src,form=fakeentry
user_agent no value no value
suhosin
This server is protected with the Suhosin Extension 0.9.29
Copyright (c) 2006-2007 Hardened-PHP Project
Copyright (c) 2007-2008 SektionEins GmbH
suhosin.apc_bug_workaround Off Off
suhosin.cookie.checkraddr 0 0
suhosin.cookie.cryptdocroot On On
suhosin.cookie.cryptkey [ protected ] [ protected ]
suhosin.cookie.cryptlist no value no value
suhosin.cookie.cryptraddr 0 0
suhosin.cookie.cryptua On On
suhosin.cookie.disallow_nul 1 1
suhosin.cookie.disallow_ws 1 1
suhosin.cookie.encrypt Off Off
suhosin.cookie.max_array_depth 50 50
suhosin.cookie.max_array_index_length 64 64
suhosin.cookie.max_name_length 64 64
suhosin.cookie.max_totalname_length 256 256
suhosin.cookie.max_value_length 10000 10000
suhosin.cookie.max_vars 100 100
suhosin.cookie.plainlist no value no value
suhosin.coredump Off Off
suhosin.disable.display_errors Off Off
suhosin.executor.allow_symlink Off Off
suhosin.executor.disable_emodifier Off Off
suhosin.executor.disable_eval Off Off
suhosin.executor.eval.blacklist no value no value
suhosin.executor.eval.whitelist no value no value
suhosin.executor.func.blacklist no value no value
suhosin.executor.func.whitelist no value no value
suhosin.executor.include.allow_writable_files On On
suhosin.executor.include.blacklist no value no value
suhosin.executor.include.max_traversal 0 0
suhosin.executor.include.whitelist no value no value
suhosin.executor.max_depth 0 0
suhosin.filter.action no value no value
suhosin.get.disallow_nul 1 1
suhosin.get.disallow_ws 0 0
suhosin.get.max_array_depth 50 50
suhosin.get.max_array_index_length 64 64
suhosin.get.max_name_length 64 64
suhosin.get.max_totalname_length 256 256
suhosin.get.max_value_length 512 512
suhosin.get.max_vars 100 100
suhosin.log.file 0 0
suhosin.log.file.name no value no value
suhosin.log.phpscript 0 0
suhosin.log.phpscript.is_safe Off Off
suhosin.log.phpscript.name no value no value
suhosin.log.sapi 0 0
suhosin.log.script 0 0
suhosin.log.script.name no value no value
suhosin.log.syslog no value no value
suhosin.log.syslog.facility no value no value
suhosin.log.syslog.priority no value no value
suhosin.log.use-x-forwarded-for Off Off
suhosin.mail.protect 1 1
suhosin.memory_limit 0 0
suhosin.mt_srand.ignore On On
suhosin.multiheader Off Off
suhosin.perdir 0 0
suhosin.post.disallow_nul 1 1
suhosin.post.disallow_ws 0 0
suhosin.post.max_array_depth 50 50
suhosin.post.max_array_index_length 64 64
suhosin.post.max_name_length 64 64
suhosin.post.max_totalname_length 256 256
suhosin.post.max_value_length 1000000 1000000
suhosin.post.max_vars 1000 1000
suhosin.protectkey On On
suhosin.request.disallow_nul 1 1
suhosin.request.disallow_ws 0 0
suhosin.request.max_array_depth 50 50
suhosin.request.max_array_index_length 64 64
suhosin.request.max_totalname_length 256 256
suhosin.request.max_value_length 1000000 1000000
suhosin.request.max_varname_length 64 64
suhosin.request.max_vars 1000 1000
suhosin.server.encode On On
suhosin.server.strip On On
suhosin.session.checkraddr 0 0
suhosin.session.cryptdocroot On On
suhosin.session.cryptkey [ protected ] [ protected ]
suhosin.session.cryptraddr 0 0
suhosin.session.cryptua Off Off
suhosin.session.encrypt On On
suhosin.session.max_id_length 128 128
suhosin.simulation Off Off
suhosin.sql.bailout_on_error Off Off
suhosin.sql.comment 0 0
suhosin.sql.multiselect 0 0
suhosin.sql.opencomment 0 0
suhosin.sql.union 0 0
suhosin.sql.user_postfix no value no value
suhosin.sql.user_prefix no value no value
suhosin.srand.ignore On On
suhosin.stealth On On
suhosin.upload.disallow_binary 0 0
suhosin.upload.disallow_elf 1 1
suhosin.upload.max_uploads 25 25
suhosin.upload.remove_binary 0 0
suhosin.upload.verification_script no value no value
sysvmsg
sysvmsg support enabled
Revision $Revision: 272370 $
tidy
Tidy support enabled
libTidy Release 31 October 2006
Extension Version 2.0 ($Id: tidy.c 272922 2009-01-06 23:45:16Z iliaa $)
tidy.clean_output no value no value
tidy.default_config no value no value
tokenizer
Tokenizer Support enabled
wddx
WDDX Support enabled
WDDX Session Serializer enabled
xml
XML Support active
XML Namespace Support active
libxml2 Version 2.7.3
xmlreader
XMLReader enabled
xmlrpc
core library version xmlrpc-epi v. 0.51
php extension version 0.51
author Dan Libby
homepage http://xmlrpc-epi.sourceforge.net
open sourced by Epinions.com
xmlwriter
XMLWriter enabled
xsl
XSL enabled
libxslt Version 1.1.24
libxslt compiled against libxml Version 2.7.3
EXSLT enabled
libexslt Version 1.1.24
zip
Zip enabled
Extension Version $Id: php_zip.c 276389 2009-02-24 23:55:14Z iliaa $
Zip version 1.9.1
Libzip version 0.9.0
zlib
ZLib Support enabled
Stream Wrapper support compress.zlib://
Stream Filter support zlib.inflate, zlib.deflate
Compiled Version 1.2.3
Linked Version 1.2.3
zlib.output_compression Off Off
zlib.output_compression_level -1 -1
zlib.output_handler no value no value
Additional Modules
Module Name
readline
sysvsem
sysvshm
Environment
Variable Value
MANPATH no value
NNTPSERVER news
HOSTNAME linux-75tb
XKEYSYMDB /usr/share/X11/XKeysymDB
SHELL /bin/bash
TERM xterm
HOST linux-75tb
HISTSIZE 1000
PROFILEREAD true
SSH_CLIENT 192.168.5.3 59879 22
get_module_list_done true
SSH_TTY /dev/pts/0
LC_ALL POSIX
USER lisss
JRE_HOME /usr/lib/jvm/jre
LS_COLORS no=00:fi=00:di=01;34:ln=00;36:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=41;33;01:ex=00;32:*.cmd=00;32:*.exe=01;32:*.com=01;32:*.bat=01;32:*.btm=01;32:*.dll=01;32:*.tar=00;31:*.tbz=00;31:*.tgz=00;31:*.rpm=00;31:*.deb=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.lzma=00;31:*.zip=00;31:*.zoo=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.tb2=00;31:*.tz2=00;31:*.tbz2=00;31:*.xz=00;31:*.avi=01;35:*.bmp=01;35:*.fli=01;35:*.gif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mng=01;35:*.mov=01;35:*.mpg=01;35:*.pcx=01;35:*.pbm=01;35:*.pgm=01;35:*.png=01;35:*.ppm=01;35:*.tga=01;35:*.tif=01;35:*.xbm=01;35:*.xpm=01;35:*.dl=01;35:*.gl=01;35:*.wmv=01;35:*.aiff=00;32:*.au=00;32:*.mid=00;32:*.mp3=00;32:*.ogg=00;32:*.voc=00;32:*.wav=00;32:
XNLSPATH /usr/X11R6/lib/X11/nls
ENV /etc/bash.bashrc
HOSTTYPE i386
FROM_HEADER no value
COLUMNS 145
CSHEDIT emacs
XDG_CONFIG_DIRS /etc/xdg
get_includes_done true
MINICOM -c on
MAIL /var/mail/lisss
CPU i686
SSH_SENDS_LOCALE yes
JAVA_BINDIR /usr/lib/jvm/jre/bin
PWD /svalka/rpms
INPUTRC /home/lisss/.inputrc
JAVA_HOME /usr/lib/jvm/jre
LANG ru_RU.UTF-8
PYTHONSTARTUP /etc/pythonstart
LINES 43
HOME /var/lib/apache2
SHLVL 4
OSTYPE linux
LS_OPTIONS -A -N --color=tty -T 0
LOGNAME lisss
MACHTYPE i686-suse-linux
G_FILENAME_ENCODING @locale,UTF-8,KOI8-R,CP1251
SSH_CONNECTION 192.168.5.3 59879 192.168.5.2 22
XDG_DATA_DIRS /usr/share
G_BROKEN_FILENAMES 1
COLORTERM 1
JAVA_ROOT /usr/lib/jvm/jre
mc () { . /usr/share/mc/bin/mc-wrapper.sh }
_ /sbin/startproc
PREVLEVEL N
RUNLEVEL 3
DAEMON /usr/sbin/httpd2-prefork
PHP Variables
Variable Value
_REQUEST["__utmz"] 18754809.1285941579.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)
_REQUEST["PHPSESSID"] see31uahnks95ehe6fb5mdl8nq7h8f6e
_REQUEST["__utma"] 18754809.1389112700.1285941579.1285941579.1286956130.2
_REQUEST["__utmc"] 18754809
_REQUEST["__utmb"] 18754809.1.10.1286956130
_COOKIE["__utmz"] 18754809.1285941579.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)
_COOKIE["PHPSESSID"] see31uahnks95ehe6fb5mdl8nq7h8f6e
_COOKIE["__utma"] 18754809.1389112700.1285941579.1285941579.1286956130.2
_COOKIE["__utmc"] 18754809
_COOKIE["__utmb"] 18754809.1.10.1286956130
_SERVER["HTTP_HOST"] 192.168.5.2
_SERVER["HTTP_CONNECTION"] keep-alive
_SERVER["HTTP_ACCEPT"] application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
_SERVER["HTTP_USER_AGENT"] Mozilla/5.0 (X11; U; Linux i686; en-US) AppleWebKit/534.3 (KHTML, like Gecko) Chrome/6.0.472.63 Safari/534.3
_SERVER["HTTP_ACCEPT_ENCODING"] gzip,deflate,sdch
_SERVER["HTTP_ACCEPT_LANGUAGE"] ru-RU,ru;q=0.8,en-US;q=0.6,en;q=0.4
_SERVER["HTTP_ACCEPT_CHARSET"] windows-1251,utf-8;q=0.7,*;q=0.3
_SERVER["HTTP_COOKIE"] __utmz=18754809.1285941579.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); PHPSESSID=see31uahnks95ehe6fb5mdl8nq7h8f6e; __utma=18754809.1389112700.1285941579.1285941579.1286956130.2; __utmc=18754809; __utmb=18754809.1.10.1286956130
_SERVER["PATH"] /home/lisss/bin:/usr/local/bin:/usr/bin:/sbin:/usr/sbin:/bin:/usr/X11R6/bin:/usr/games:/usr/lib/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin
_SERVER["SERVER_SIGNATURE"] no value
_SERVER["SERVER_SOFTWARE"] Apache
_SERVER["SERVER_NAME"] 192.168.5.2
_SERVER["SERVER_ADDR"] 192.168.5.2
_SERVER["SERVER_PORT"] 80
_SERVER["REMOTE_ADDR"] 192.168.5.3
_SERVER["DOCUMENT_ROOT"] /srv/www/sauerclan
_SERVER["SERVER_ADMIN"] horonitel@gmail.com
_SERVER["SCRIPT_FILENAME"] /srv/www/sauerclan/phpi.php
_SERVER["REMOTE_PORT"] 59602
_SERVER["GATEWAY_INTERFACE"] CGI/1.1
_SERVER["SERVER_PROTOCOL"] HTTP/1.1
_SERVER["REQUEST_METHOD"] GET
_SERVER["QUERY_STRING"] no value
_SERVER["REQUEST_URI"] /phpi.php
_SERVER["SCRIPT_NAME"] /phpi.php
_SERVER["PHP_SELF"] /phpi.php
_SERVER["REQUEST_TIME"] 1286954772
PHP License
This program is free software; you can redistribute it and/or modify it under the terms of the PHP License as published by the PHP Group and included in the distribution in the file: LICENSE
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
If you did not receive a copy of the PHP license, or have any questions about PHP licensing, please contact license@php.net.
Чесно говоря, не вижу вообще, чтобы Ice был подключен хоть как-то.... кроме файла /etc/php5/conf.d/ice.ini
Что там?
Что там?
extension=IcePHP.so
Еще раз внимательно прочтите https://wiki.mumble.info/wiki/Ice
Читаю. И вижу, что до настройки PHP я должен увидеть открытый порт 6502
А я его не вижу... Я взял Ice из рекомендованых там репов. Что еще я там увидеть должен?
Getting ready to use Ice
To enable Ice in your murmur.ini configuration file first comment out
dbus=session
to disable dbus and add / uncomment
to enable Ice for localhost on port 6502.
To check if Ice in fact does listen, on unix type
netstat -apn | grep 6502
on windows type
netstat -an | grep 6502
Я был бы очень рад, если бы вы дали мне пошаговую инструкцию по выполнению установки с нуля на русском.
viewtopic.php?p=1723#p1723
порт у Вас станет прослушиваться, только после того как Вы установите, настроите и запустите Mumble+Ice
1. Устанавливаем ICE (ice-3.4.1)
2. Привязываем его к PHP (ice-php-3.4.1)
3. Настраиваем ICE и mumble.ini
4. Рестартим апач
5. Запускаем Мамбл
Попытался откатить php до 5.2.6 - ошибка та же. вернул обратно. Причем, повторюсь, у меня 2 машины, на обоих одинаковая фигня. Значит, идеи кончились?
1. Установите Ice версии 3.3.1
2. PHP версии 5.2.6
3. И расширение php5-ice к нему.
Проверьте "php -m" на наличие ice в списке модулей.
2. PHP версии 5.2.6
