<W>2011-09-16 16:14:40.537 Initializing settings from C:/Program Files (x86)/Mumble/murmur.ini (basepath C:/Program Files (x86)/Mumble)
<W>2011-09-16 16:14:40.558 OpenSSL: OpenSSL 1.0.0c 2 Dec 2010
<W>2011-09-16 16:14:40.561 SSL: Adding recommended CA AAA Certificate Services
<W>2011-09-16 16:14:40.562 SSL: Adding recommended CA UTN-USERFirst-Client Authentication and Email
<W>2011-09-16 16:14:40.564 ServerDB: Openend SQLite database C:/Users/OrangeFruit/murmur.sqlite
<W>2011-09-16 16:14:40.573 MurmurIce: Endpoint "tcp -h 127.0.0.1 -p 6502" running
<W>2011-09-16 16:14:40.574 Murmur 1.2.3 (1.2.3) running on Win: 6.1.7601.1: Booting servers
<W>2011-09-16 16:14:40.680 1 => Server listening on [::]:64738
<W>2011-09-16 16:14:40.756 1 => Server listening on 0.0.0.0:64738
<W>2011-09-16 16:14:40.838 1 => Announcing server via bonjour
<W>2011-09-16 16:14:40.908 1 => Not registering server as publicКод: Выделить всё
database=
#dbDriver=QMYSQL
#dbUsername=
#dbPassword=
#dbHost=
#dbPort=
#dbPrefix=murmur_
#dbOpts=
dbus=session
# You can set a plaintext "secret" on the Ice connection, and
# any script attempting to access must then have this secret
# (as context with name "secret").
# Access is split in read (look only) and write (modify)
# operations. Write access always includes read access,
# unless read is explicitly denied (see note below).
# Note that if this is uncommented and with empty content,
# access will be denied.
#icesecretread=
icesecretwrite=
#autobanAttempts = 10
#autobanTimeframe = 120
#autobanTime = 300
#logfile=murmur.log
#pidfile=
welcometext="<br /><b>Welcome to server vtz team.<br />Enjoy your stay!</b><br />"
port=64738
#host=cs.irteam.ru
# Password to join server
serverpassword=
# to send speech at.
bandwidth=140000
users=300
#textmessagelength=5000
#imagemessagelength=131072
#allowhtml=true
# Set to 0 to keep forever, or -1 to disable logging to the DB
#logdays=31
# addresses.
#registerName=VTZ team <-> WoT
#registerPassword=test
#registerUrl=http://cs.irteam.ru
#registerHostname=cs.irteam.ru
# about bonjour.
#bonjour=True
# Otherwise, Murmur will create it's own certificate automatically.
#sslCert=
#sslKey=
#uname=
# to connect.
#certrequired=False
[Ice]
Ice.Warn.UnknownProperties=1
Ice.MessageSizeMax=65536
