Здравствуйте, сервер падает на данной ошибке, как её решить*? И в чём может быть проблема?
Сама ошибка:
[hide]<W>2011-06-29 13:16:24.772 1 => <1467:naher(-1)> Connection closed: The remote host closed the connection [1]
<W>2011-06-29 13:27:23.483 Initializing settings from /usr/local/games/voice/murmur/murmur/murmur.ini (basepath /usr/local/games/voice/murmur/murmur)
<W>2011-06-29 13:27:23.527 SSL: Added CA certificates from '/etc/ssl/certs/ca-certificates.crt'
<C>2011-06-29 13:27:23.536 WARNING: You are running murmurd as root, without setting a uname in the ini file. This might be a security risk.
<W>2011-06-29 13:27:23.537 ServerDB: Openend SQLite database /usr/local/games/voice/murmur/murmur/mumble
<W>2011-06-29 13:27:23.539 Resource limits were 0 0
<W>2011-06-29 13:27:23.539 Successfully dropped capabilities
<W>2011-06-29 13:27:23.540 Failed to connect to D-Bus session
<W>2011-06-29 13:27:24.568 Murmur 1.2.2 (Compiled Feb 9 2010 17:44:13) running on X11: Debian GNU/Linux 6.0.1 (squeeze): Booting servers[/hide]
Падение сервера
Падение сервера
Последний раз редактировалось sayber 29 июн 2011, 13:28, всего редактировалось 1 раз.
Re: Падение сервера
Вчера на этой же ошибке упал mumble... Как решить её? И исправить, чтобы не падал больше... 1 год простоял почти без падений)))
[spoiler]<W>2011-06-27 19:59:46.393 1 => <4715:En4ZenT(135)> Kicked Moleculo:4857(-1) ()
<W>2011-06-27 19:59:46.425 1 => <4857:Moleculo(-1)> Connection closed: [-1]
<W>2011-06-27 19:59:52.988 1 => <4930:(-1)> New connection: 188.134.27.114:57375
<W>2011-06-27 19:59:53.090 1 => <4930:(-1)> Client version 1.2.2 (Win: 1.2.2)
<W>2011-06-27 19:59:53.112 1 => <4930:Moleculo(-1)> Authenticated
<W>2011-06-27 19:59:54.119 1 => <4925:mw.(-1)> Moved mw.:4925(-1) to S-Power[225:8]
<W>2011-06-27 20:00:06.617 1 => <4930:Moleculo(-1)> Connection closed: The remote host closed the connection [1]
<W>2011-06-27 20:01:28.636 Initializing settings from /usr/local/games/voice/murmur/murmur/murmur.ini (basepath /usr/local/games/voice/murmur/murmur)
<W>2011-06-27 20:01:28.679 SSL: Added CA certificates from '/etc/ssl/certs/ca-certificates.crt'
<C>2011-06-27 20:01:28.687 WARNING: You are running murmurd as root, without setting a uname in the ini file. This might be a security risk.
<W>2011-06-27 20:01:28.692 ServerDB: Openend SQLite database /usr/local/games/voice/murmur/murmur/mumble
<W>2011-06-27 20:01:28.696 Resource limits were 0 0
<W>2011-06-27 20:01:28.696 Successfully dropped capabilities
<W>2011-06-27 20:01:28.717 Failed to connect to D-Bus session
<W>2011-06-27 20:01:29.079 Murmur 1.2.2 (Compiled Feb 9 2010 17:44:13) running on X11: Debian GNU/Linux 6.0.1 (squeeze): Booting servers
<W>2011-06-27 20:01:29.319 1 => Server listening on [::]:64738
<W>2011-06-27 20:01:29.867 1 => Announcing server via bonjour
<W>2011-06-27 20:01:29.907 1 => Not registering server as public
<W>2011-06-27 20:01:29.923 1 => <1:(-1)> New connection: IP:4088
<W>2011-06-27 20:01:29.941 1 => <2:(-1)> New connection: IP:62215
<W>2011-06-27 20:01:29.989 1 => <3:(-1)> New connection: IP:2499
<W>2011-06-27 20:01:30.048 1 => <4:(-1)> New connection: IP:56272
<W>2011-06-27 20:01:30.073 1 => <5:(-1)> New connection: IP:1796
<W>2011-06-27 20:01:30.106 1 => <6:(-1)> New connection: IP:52987
<W>2011-06-27 20:01:30.120 1 => <7:(-1)> New connection: IP:57191
<W>2011-06-27 20:01:30.138 1 => <8:(-1)> New connection: IP:2737[/spoiler]
Это вчерашний лОг!
Это вчерашний лОг!
Re: Падение сервера
Собственно, где в логах Вы видите ошибку?
<--- Хочешь себе такой? Читай тутRe: Падение сервера
К примеру <C>2011-06-27 20:01:28.687 WARNING: You are running murmurd as root, without setting a uname in the ini file. This might be a security risk.
С чем вызвано может быть? Мамбл падает во время этой ошибки...
Re: Падение сервера
Это не ошибка. Это обычные стартовые сообщения.
Первое говорит о том, что Вы запускаете сервер от рута и предупреждает, что это может вызвать проблемы безопасности сервера.
Второе сообщает, что была открыта SQLite база данных по указанному адресу.
Это нормальный лог старта сервера, если после старта вы можете к нему подключиться.
Смотрите логи после падения, как системные так и мамбла.
И переводите на mysql. =)
